Reactivation of old sim card
Sureshsathirara
Can i reactivate my old sim Card which has not been in use for 1 year. I am currently staying abroad. Please help me with your suggestions.
@Sureshsathirara   It’s not possible to reactivate a year old SIM card.   You have 180 days after the sim has gone in to hibernation to get it reactivated and SIM cards go in to hibernation after 3 months of no usage.
Thanks... Is there any way to get a sim card with same number which i had used before. If so does this require any ID proof to get a dulpicate sim.. Currently am not staying in UK.. Is it possible to get the sim if someone else go to nearby EE. Shop on my behalf..
Hi @Sureshsathirara.
Numbers that go into hibernation will be recycled and often re-used, so unfortunately it's not possible to get the same number back.
Jon
