on 27-10-2021 10:16 AM
Hello mine still isn’t working. Ive got the same error message as the rest. Does mine need resetting?
thanks 😊
on 27-10-2021 10:18 AM
27-10-2021 10:20 AM - edited 27-10-2021 10:25 AM
Hello it’s showing
Your account has been deactivated as your registration was not completed within the allowed time frame.
ive spoken to my work and like the rest that have mentioned in their responses, my company doesn’t know anything about resetting it.
on 27-10-2021 10:29 AM
Hi @Zee10,
I can help you with this, but I'll to contact you via private message. Please could you make sure your private messages are enabled by going to your community settings > select the preferences tab > select private messenger from the drop down.
on 27-10-2021 11:56 AM
I can’t seem to find the community settings are u able to contact me in any other way or tell me how to get to community settings
on 27-10-2021 12:30 PM
Hi @Zee10,
You can access your community settings by tapping/clicking your avatar at the top of the home page.
Hope this helps.
on 27-10-2021 07:46 PM
Thanks I’ve updated it
on 28-10-2021 08:45 AM
Hi @Zee10
Thanks for updating this.
Can you send me a private message with the email address you used to register?
28-10-2021 11:16 AM - edited 28-10-2021 11:21 AM
Hello I don't have any options to send you a private message or see my private messages. @Leanne_T
when i click on private message it says: You do not have sufficient privileges for this resource or its parent to perform this action.
on 28-10-2021 11:22 AM
