close
Re: Starting pack early
John68W
Hi, I want to start my next pack early but my SIM is in a WiFi dongle. Will I have to put the SIM in my phone then text NOW to 150 or can I do it another way?
TIA
6 REPLIES 6
Christopher_B
EE Employee
Hi @John68W
Welcome to the EE Community 😊
I hope you're well and having a nice weekend, are you up to much or just having a chilled one?
Is the SIM that's in your WiFi dongle a data only SIM?
Hi @Christopher_B,
My allowance balance says I have mins and texts so not data only. I would
prefer data only though
@John68W Thanks
Have you registered the SIM on My EE to be able to manage it online?
Yes
Thanks @John68W
You should be able to manage your packs via your My EE account.
If you login does it allow you to do so?
@John68W : Probably not as most mobile WiFi routers allow you to send texts from them. Which 1 have you got?
