close
Re: Blue Light discount code not working
Maz733
Hya I’m experiencing a problem with my blue light discount code I’m trying to upgrade to iPhone 13  pro it’s not on promotion so can you advise please
maria
Leanne_T
Hi @Maz733
Did you get the code from the EE Perk portal?
What happens when you enter the code?
Thanks 🙂
Leanne
i got it via blue light app I copied and pasted that way but says not valued code
regards
Maria
Leanne_T
Hi @Maz733
You would need to get the perk code from the EE Perk portal.
If you can register or log in you will get your discount codes.
