close
Quick panel
Amiles33
Hi. My quick panel and phone settings in  general have gone weird. When I swipe down my whole screen goes blurred but if I randomly tap on where I know some off the icons usually are it works. I just can't see anything. Has anyone else had this and know how to fit it? Thanks. Have a Samsung
All sorted! I called EE and they suggested soft reset initially, which worked!
Amiles33
Northerner
Hi @Amiles33
Backup your device and then factory reset.
If that doesn't help then you might need to contact Samsung and claim on your Samsung warranty.
