close
router down steaming speed
stephen13204
this  is to  inform you i a  losing my   down load speed  was 38  / 39mb   on my router  i have a  bt eng   coming thursday    its now at   35.27     i spoke to customer services  videos are slow and shopping slow to  also   i notices   smar hub management works well with mac  not windows edge i am  a coms eng  35 experance  i am concerned i get hold borad team weekends at times
@stephen13204 : Welcome to EE's Home Broadband Forum.
You are not informing EE. This is a user discussion forum which can have no access to your specific account. Nor are you roaming with BB.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
