close
Preloaded pack payg
Marq79
Hi
i want to cancel the pack I have on the sim and just use as traditional payg.
I have texted STOP to 150 but the text reply after adding £5 says this is credited against the £20 pack that I don’t want. How do I move away from the pack immediately? Thanks
All EE PAYG SIMs come primed with a recurring Pack of allowances ready to bought out of your PAYG credit as soon as it is sufficient. Your last top-up went to buy this Pack.
By texting AL to 150 it should show you the Pack you have bought with your credit & how much you have left from your allowances until its expiry date.
Text STOP PACK to 150 before you next top-up & you can use the SIM for calls & texts but not data as normal PAYG at standard per-unit rates paid for out of your standing PAYG credit balance.
To save the SIM going into hibernation due to lack of use, just remember within every 179 days (~ 6 months) to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from any Pack or Add-on you might have.
