close
Phone number given to someone else
lwil14
I had received calls off a random number a few times to get a reply that the man on the other end was given a new ee SIM card with my number. When I called ee I was told it would be fine that no two same numbers can be activated and it must’ve been a mistake. Has anyone else had this issue?
James_B
EE Community Manager
Hi @lwil14,
The advice you were given by Customer Care was correct. If your number was allocated to another SIM, your SIM would be deactivated.
James_B
Hi @lwil14,
