close
Packs system unavailable
Cronny
I activated my new EE number on 12 August 2021 and have not been able to access the Packs. I get the below error on both the website and EE app
6 REPLIES 6
Christopher_B
EE Employee
Hi @Cronny
I hope you're well and having a nice Friday, other than this issue of course.
Do you know what Pack you're wanting, or can you not even see your options?
Hi @Christopher_B
I'm having a good Friday thanks and you?
I'm completely new to EE and I'm unable to see any of the Pack options.
I'm having a good one @Cronny, thanks for asking.
Can I just double check how long your number has been active?
@Cronny :
  • Text AL to 150 to see if you have a pack.
  • Text ALL PACKS to 150 to see what packs you may buy. However £3.95 is not enough to buy a pack. You will need to top-up.
@Christopher_B  the sim was bought in May I think but only activated on 12 August, so 15 days now.
@Christopher_B  buying a new pack has solved the problem, thanks for your support.
