Osprey mini flashing red light
Swansong
Mifi red light flashing at 4g for last couple of hours can't connect to internet
6 REPLIES 6
Alex_S
EE Employee
Hi @Swansong,
Welcome to the community 🙂
Can you let me know which mobile MiFi device you are using?
Do you have an EE signal on your mobile phone in the same area?
Alex 🙂
Are the 3G & SMS lights green?
 In the same placeHi yes I have a mobile signal with ee
Hi it is an osprey mini , called ee said I had a flashing red 4g light on myfi and couldn't connect to internet ,was advised to use a pin and reset the device but this made it worse did have one blue light alongside the red flashing light ,that blue light has now vanished ,the guy I spoke to said he couldn't do anything and someone would be in touch in the next 24hrs !
Hi only have 1 light on my osprey mini and that is red and flashing ,not had this problem before, all lights are on at beginning then only 1 red light
What ALL lights if it has only 1 light?
I have the Osprey Mini & it has:
  • On top, a line of yellow lights indicating signal strength.
  • Below those, 3 blue when lit lights, 4G, 3G & Envelope (SMS).
  • At front, the power button with 4 yellow sectored lights indicating battery strength.
