Not able to make phone calls or receive
MitchEast_
I am currently on an iPhone XR my data works completely fine whereas my sim isn’t allowing me to take calls or make calls
Jon_K
Former EE Employee
Hi @MitchEast_
Welcome to the community.
What happens when you try to make a call?
Do you get an error message?
Can you send and receive texts?
Jon
When I make calls it doesn’t even ring I can send messages and use data fine , when someone tries to call me it says this number isn’t taking calls right now
Sent from my iPhone
Jon_K
Former EE Employee
Thanks @MitchEast_
Can you make sure the Do Not Disturb feature is turned off?
Do you have a signal on the phone, or are you using WiFi?
Jon
Yeah I have signal also DND isn’t on it allows me to use data and text fine , it’s just that when I make calls it does not go through or when I receive calls it don’t ring even though I have unlimited
Sent from my iPhone
Jon_K
Former EE Employee
Thanks @MitchEast_
Is this a new phone or have you had it a while?
Are you able to try your SIM card in another phone?
This would help to determine where the problem lies.
Jon
