27-06-2021 04:54 PM
I have had my 4gee mini Wi-fi 2020 for a couple of weeks and has been working fine but today the network won’t show on any device have tried resetting and plugging in to pc but still not able to access it any suggestions
28-06-2021 07:55 AM
Hi @Tom200
Welcome to the community.
Could you check your postcode on our network status checker please? It will let you know if there are any maintenance works in your area.
Let us know what it says.
28-06-2021 08:00 AM
I have checked The status checker and it is not showing any issues
28-06-2021 08:07 AM
OK thanks for checking, @Tom200.
I'd recommend speaking to our technical support team so they can run through some troubleshooting with you and make sure everything is as it should be on our side.
28-06-2021 08:17 AM
Are you saying that the WiFi network isn't showing on other devices, or that the EE mobile network isn't showing on the 4G device?
28-06-2021 08:20 AM
The Wi-fi network won’t show on devices
28-06-2021 09:36 AM
28-06-2021 10:58 PM
I have tried this and it just says unable to connect
28-06-2021 11:08 PM
What Device say unable to connect, the Device your using ie, phone or the Router when connected.
28-06-2021 11:48 PM
Hi @Tom200 ,
As you've mentioned the fault has developed within the first few weeks, I would highly recommend you review the returns policy depending on whether you made the purchase in a retail store or online.
Retail purchases have a 30 day window for fault returns so you don't want to run down that timer with experimentation. If bought in a store, at some point it would be worth returning for diagnostics. Similarly if bought via another route.
https://ee.co.uk/content/dam/ee-help/help-pdfs/ee-device-returns-policy-v2-june-2018.pdf
