New Phone and PAC Code question
Appleton70
Hello there.
I have just left Vodafone for EE and have a PAC code ready to use.
My new phone is the Samsung S20+ and my old/current phone is the Samsung S9+.
My question is; do I transfer everything from my S9+ to the S20+ and then send the PAC Code to EE?
Or should I do it the other way round?
And is Smartswitch the best and simplest way to transfer all my numbers, apps and photo's etc?
I'm not the best with technology so appreciate your help.
Sean
9 REPLIES 9
@Appleton70 : You may use the PAC at any time. All it does is change the mobile no. of the new phone.
Samsung Smart Switch should do the job.
@XRaySpeX  thank you so much for your quick response, much appreciated.
Do I assume that when I've copied everything over, all my contacts and apps etc actually exist on both devices?
Thanks again
Leanne_T
Hi @Appleton70
Yes, you should have all your data on both phones 🙂
Hope this answers everything for you.
ok, great, thanks Leanne_T
Everything has gone ok thank you, I'm just waiting for the number transfer after submitting my PAC code form this morning.  So my new number should be live tomorrow......right!?
Thank you again!
Leanne_T
Hi @Appleton70
Thanks for coming back to me.
This should be tomorrow for you if the request was before 5:30pm, if you would like to check your number transfer is all set up for you please give us a call on 150 🙂
Thanks.
OK great, I'll do that.  Thanks very much again for your help Leanne!! 😁
Leanne_T
No problem at all @Appleton70
All the best 🙂
How do you submit a pac code please? I have it but not sure where to do it?
@Lb41 Give your PAC from old provider to EE using Fill out this quick form to transfer your number .
