close
My we WiFi mini is not working, the WiFi signal stays red
Db119962
I’ve switched the device on and off several times, I’ve also reset the device and nothing works. This is the second device that this has happened to, not good at all.
mikeliuk
Are you able to connect to it by WiFi or wired to see what might be wrong?
https://ee.co.uk/help/help-new/phones-and-devices/ee/4gee-wifi-mini#getting-started/view-the-device-...
Leanne_T
Hi @Db119962
Do we have any problems showing for your area on the Coverage and Network Status Checker? If you enter the postcode and select 'Check Network'
Thanks 🙂
