close
My voicemail won't connect
Greekofile
My voicemail has stopped connecting over the past week, for no obvious reason. I get constant messages on my phone and watch saying I have a voicemail but when I try to phone voicemail I am getting a message saying Call Failed : 'Error performing request. Unknown Error'
Any suggestions?
@Greekofile   Try texting VM OFF to 150 then turn the device off/on then text VM ON to 150 and test it.
Thanks, I tried that but it hasn't made any difference.
Are you using Visual Voicemail on your iphone? Test IPHONE VISUAL to 150
Hi @Greekofile
Does the same error occur whether you are using speed-dial 1 and/or manually dialling 222?
Interesting! I had been just following the links but when I dialled 222 it worked. It will be interesting to see if this solves the problem. It does seem to have stopped the continual messages.
