close
4gee
Jordan216
Hi all,
i have had trouble with my 4GEE WIFI MINI recently. Firstly it stopped working and the wifi couldnt be found so this was sent off to EE and found there was a fault with it so it had a software update, ive just had it back and wifi works fine but now im having trouble with the network connection its a constant red light and wont connect to internet at all.
Leanne_T
Morning @Jordan216
Do you have any other EE devices having the same issue?
Did you get a replacement SIM card?
Thanks 🙂
No my iphone device works fine.
No didnt get any new sim card. Could this be the issue with the WIFI MINI having a software update? i will need a new sim card for it?
Katie_J
Hello @Jordan216
Is the SIM still in the device?
Do you have data available? you can check this by logging in to your My EE.
Katie 🙂
