close
LTE 4G USB Modem: Does anyone have one of these working?
Crustyfur
I bought one of these https://www.wish.com/product/609272794c21617cf5496e59 and have been struggling to get it working.
Initially, in the Settings interface I configured it with what I presumed would work:
MccMnc: 23430
Number: *99# <or leave blank>
Username: eesecure
Password: secure
Apn: everywhere
Priority Net: Auto
The device fails to connect. I've tried all sorts of other options and cannot get it to connect.
Any suggestions anyone?
EssexBoyEE
The APN settings you have posted are correct, but I believe you may struggle to get any kind of technical support from any Mobile Device that is purchased from Wish as most of them are Over Spec or Fake goods from China.
I think you're right.
Managed to find a second-hand EE 4G Hub thing on eBay, so am going to give that a go.
Thanks.
