close
Keeping my number
Profile closed
Not applicable
I have received my new ee sim, registered a account and now trying to transfer my number..
I go to this https://myaccount.ee.co.uk/app/keeping-your-number
enter my pac code, then it askes for ee number and number to transfer it auto fills the correct ee number but I get this error
"Please make sure you enter the right phone number. It must be a UK phone number and start with 07."
I have checked and double checked but I am unable to continue because of this error.
I have given up on giffgaff due to incompetents and pore network service. but unable to complete this simple task makes me wonder.
how can I transfer my number????
Profile closed
Not applicable
thanks but no thanks...
tried to phone 150 but cant as it costs 25p. I am not topping up until I transfer number...
phoned the 0800 number closes at 9pm...... incompetent...
Vodaphone no problems, pac code accepted and is under way....
ee you lost a customer. Vodaphone here I come.. now i just need to close this ee account.
Hi @Profile closed
If you're having problems submitting your PAC online, I'd recommend calling EE C/S to do the same.
You can do so on 150 from your mobile, or 0800 0798586 from any other phone.
Profile closed
Not applicable
If this is a PAYG SIM there's nothing to close. Just don't use the EE SIM.
Profile closed
Not applicable
Yes there is.
I had to join @Ee.co.uk/join to try to transfer number... I also had make this community account to post here........
Both are unnecessary and unneeded! I will get them removed from the system.....
Christopher_G
I've sent you a private message to get some information from you, @Profile closed
Could you have a look and get back to me.
