close
Internet.
K8tie
My internet connection is absolute pants! It was running at 11meg the other day and you want me to pay 32 quid a month!!!! Not happy. Ufibre are offering a much better deal!
@K8tie : Welcome to EE's Home Broadband Forum.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
