Impossible to login
Guifutre
What's going on with this website that doesn't allow login since yesterday???? Trying to register a new card and ask for my number portability and the system says no... What a nice start 😞
7 REPLIES 7
Give your PAC from your old provider to EE using Fill out this quick form to transfer your number .
mikeliuk
Hi @Guifutre ,
Have you tried an incognito tab or InPrivate tab?
It doesn't seem that you are looking to port a number from another network provider to EE?
@mikeliuk : Number portability only occurs between providers. It is not meaningful within a single network.
I didn't but I will try. Thank you.
Doesn't work 😒
Thanks for sending the form but firstly I need to know why am I not allowed to log in... Is it just me or is the website? Thank you.
Hi @Guifutre ,
It seems to be an issue with the website that you cannot login. Typically switching to another device or browser may help. If you are locked out for a valid reason, it would then make sense to contact EE to look at your online account.
