close
IPHONE SE 2020 Insta and Snapchat not working
Wesley8
Hi! I for got the pass code to my iPhone SE 2020 so did a Restore and then a Backup. Instagram and Snapchat are now not working - states there is no Internet connection. Here is what I tried so far  ..
Deleted and reinstalled both apps
Powered WiFi router on and off
Network Reset
Did Forget Device and then reconnected.
WiFi is working fine, I can access browser / sites.
Checked Usage Controls are set to Full Access
Any advice as not sure what else to check?
Thanks!!
Leanne_T
Hi @Wesley8
If you go into your iPhone Settings and select Mobile Data, if you scroll down to the apps, are they set to use data?
Thanks 🙂
@Wesley8  Do they work over cellular data ?  At the moment it could be your WiFi that’s the issue.  Any app that’s not working over WiFi isn’t an EE network issue it’s your WiFi.
