How do I restore voicemail
Kamikaze
I need to recover a voicemail I deleted. If I go to phone, voicemail I should get a list there but all I get is “call voicemail”. Any ideas?
Kamikaze
Sorry the screenshot has not posted.
I think it has. It was just awaiting approval.
Once you delete a VM you cannot listen to it again. Had you not deleted it you would have had 7 days to listen to it again.
I don't know about Apple Visual Voicemail, but for EE standard voicemail...
If a message is deposited, it is held as "new" for upto 21days.
Once a message is listened to and "saved", it's kept for 7 days.
Once it's deleted and you terminate the voicemail call, that message is gone.
