close
Hot spot drop out
Bob3003
Good day all
I use my hot spot for my android car stereo but it connect then after a few minutes it disconnects  - I’m using the latest iPhone -
is this a setting in my phone or EE problem ?
best regards
Bob
9 REPLIES 9
Hello @Bob3003
Are you saying the hotspot functionality is dropping? (This is a device function)
Or that your mobile data is stopping, thus affecting the hotspot?
It’s not the device it’s the phone dropping out I think
Sent from my iPad
When the hotspot functionality drops, does your device/phone still have a working mobile data connection?
Yes it’s still got coverage
Sent from my iPad
James_B
EE Community Manager
Hi @Bob3003,
Does your car remain connected to the hotspot, but have no internet connection, or disconnect from the hotspot altogether?
Hi
No the hot spot disconnect - the Bluetooth stays connected but the hot spot is over wfi
Cheers
Sent from my iPad
James_B
Hi @Bob3003,
When your car disconnects, is your hotspot still showing as active on your phone?
Could you connect a different device to your hotspot and let us know if you see the same issue?
I have used a dongle to connect to the car radio and that stayed connected fine - reading some info - I see others have a problem to saying that iPhone turns hot spot off after 90 s 🙈 but this does not happen when connecting to my iPad ?
Cheers Bob
Sent from my iPad
James_B
Hi @Bob3003,
I'd recommend contacting your car's manufacturer to see if they are aware of any compatibility issues.
Please let us know how you get on.
