Help ! Sky Q not working with EE Hub
Emmaj66
I’ve recently had sky Q installed worked perfectly fine for a total of 5 days before dropping connection to the EE Hub. Spoke to sky who basically aren’t interested said no fault with the box it’s EE hub issue which is also new. They recommended splitting the SSID which I’ve done but still the same problem I only have my phone connected to the WiFi and sky will only pick up the one (2mgz) sorry I am no way technical and if my WiFi works with my phone and sky (when it is connected) how can this be an EE issue? . I’ve also called EE who confirmed no problem with my WiFi so I’m stuck with nobody taking ownership, has anyone had the same issue ? I’m at my wits end and fed up of being on hold with sky for 45 minutes a time 😡
9 REPLIES 9
@Emmaj66 : Did you sparate the bands on the SH? Is it still that way? That's usually the way to do it.
I have little to zero technical knowledge, what’s the SH ?
SH = Smart Hub.
Yes, I kept the same name on the 5g but added sky on the end so I could tell which is which. When searching the different id’s show up on my phone and two different brands of speaker but the sky q that only picks up the 2g. It did seem to work for all of 4 days then kicked it off again
James_B
EE Community Manager
Hi @Emmaj66,
Do your other devices remain connected when your Sky Q box drops out?
It always seems to drop off overnight I only have my phone connected and 2 speakers which I’ve turned on at the same time to try and everything else is connected fine I tried an old now box and that stayed connected connected just the q box that keeps dropping off
James_B
Hi @Emmaj66,
If everything else is staying connected, it may be the TV box that is at fault.
I would recommend getting back in touch with your TV provider to see if there is anything else they can do to help.
I have the same problem! My tv won’t pick up the new 5ghz SSID And only the only one! I can’t watch anything online using my tv it’s a nightmare! Please help
@EmranA : Which router do you have? If the EE Smart Hub, have you split the WiFi bands?
