close
Hawk android 7 using SD card
bugsy7
can anyone give clear instructions how to start using a sandisk microSDXC card for storage on this phone.Am failing to switch any App storage from my full phone storage Thanks bugsy7
Northerner
Hi @bugsy7
You will find many of the apps will not be transferable to SD card.
If you go into the app settings (under settings) click on the app and it will tell you if it is transferable.
Northerner
Hi @bugsy7
