close
Green Network light
Loki2
Hi, I have been looking but can find no straight answer to why the network light on my EE 4GEE router has changed from solid blue to solid green - along with a massive drop in speed, restarted, reset, spoken to EE - who expressed amazement that I get a signal at all (I've had two years' worth of 10Mb with no problems until Thursday!)  My EE phone, sitting beside the router delivers exactly that.
So, what does a steady green network light actually mean?
Any info very gratefully received!
@Loki2   The device isn’t picking up 4G have you tried restarting the device?  Switch it off for 30+ seconds then back and and see what it does.
Hi Chris, thanks for the response.  I feared that might be the case.  Yes, multiple restarts and one reset under instruction from EE and it is staying green...
wardi
Star Contributor
Star Contributor
Loki2.. I have a 4GEE router - when a similar thing happened to me a while back there was a problem in my area.  The internet speed dropped quite dramatically but didn't disappear altogether.  Try putting your postcode into the Network Status Checker and see if there's a problem in your area.
 https://myaccount.ee.co.uk/networkchecker/checkservice
