31-10-2021 01:51 PM
I have a 5G unlimited data SIM in an unlocked Huawei CPE PRO modem from Amazon which has never been that reliable but is now driving me nuts. It drops for a few seconds at least a dozen times a day but can be more (and as I'm typing this it has dropped twice!) I know this because I listen to the radio via a smart speaker and it is very clear when it happens. As it is when streaming Amazon/BBC for example on the TV. It generally reconnects and resumes automatically except if the drop is longer.
I have ploughed through various posts and I have as recommended:
I have now come to the end of my technical limits so if anybody has any idea I'd be grateful to learn of it.
31-10-2021 01:57 PM
Hi @Jill57 ,
If the firmware is already at the latest for that particular model, I would recommend to consider returning it to the vendor as a faulty device, given the debugging which you have already performed.
31-10-2021 01:57 PM
Hi @Jill57 ,
31-10-2021 02:23 PM
Thanks for your reply Mike. Yes, the firmware is up-to-date so I have contacted Huawei as you suggested because I am of the opinion the router is not fit for purpose but I just wanted to check I hadn't overlooked anything obvious from the EE point of view. Jill
31-10-2021 02:50 PM
You may wish to consider the list of 5G routers in the below thread if you consider that the online reviews suggest the Huawei is somewhat flaky.
Netgear M5 MR5200 (retails GBP 500 to GBP 700) https://www.netgear.com/uk/home/mobile-wifi/hotspots/mr5200/ (crazy price but I think was used by some US carriers as their stock device, AT&T perhaps as an example)
ZyXEL NR5101 (retails around GBP 550) https://www.zyxel.com/uk/en/products_services/5G-NR-Indoor-Router-NR5101/ (manual under tech support and includes support for IP Passthrough, has SSH support and other things but lack of load-balancing multi-WAN has me leaning towards MR5200 for something more compact and flexible/portable)
D-Link DWR-2101 (retails around GBP 300) https://www.dlink.com/en/products/dwr-2101-5g-wi-fi-6-mobile-hotspot (probably the cheapest 5G WiFi 6 mobile router I'm aware of but ruled out as cannot be powered with battery removed)
Less noteworthy ones are:
ZyXEL NR2101 (seems to share similarities with the cheaper D-Link but also has various quality and build differences)
ZyXEL NR7101 (outdoor but lack of RJ45 reduces flexibility for consumer usage)
D-Link DWR-978 (recently found out about this one and don't know much about it)
Huawei E6878-370 (portable Balong 500)
HTC 5G Hub https://www.htc.com/uk/5g/htc-5g-hub/ (don't know much about this one)
31-10-2021 02:52 PM
What's the full CPE Model ?
Login into your Routers Admin Page, when at the Huawei Router Home Page paste this into your Browser then hit return -
http://192.168.8.1/api/device/signal
It should bring up a String of Info, copy and paste all the info to here.
31-10-2021 03:45 PM - edited 31-10-2021 04:21 PM
As requested:
4G only
91 3145474 -11.0dB -95dBm -61dBm -4dB 7 20MHz 20MHz PPusch:2dBm PPucch:0dBm PSrs:2dBm PPrach:0dBm mcsUpCarrier1:23 mcsDownCarrier1Code0:6 mcsDownCarrier1Code1:11 DL:1617 UL:19617 1 11211 3 23430 0 17517 18467 TM[4] 0012287 32639 32639 1751700kHz 1846700kHz
Model H112-372
5G on as well
91 3145480 -8.0dB -104dBm <=-113dBm 1dB 7 20MHz 20MHz PPusch:1dBm PPucch:0dBm PSrs:2dBm PPrach:2dBm mcsUpCarrier1:22 mcsDownCarrier1Code0:31 mcsDownCarrier1Code1:22 DL:3350 UL:21350 1 11211 7 No21:151No22:87 23430 0 25600 26800 TM[3] 0012287 32639 32639 2560000kHz 2680000kHz 40MHz 40MHz NRmcsUpCarrier1:31 NRmcsDownCarrier1Code0:2 NRmcsDownCarrier1Code1:0 PPusch:19dBm PPucch:13dBm PSrs:20dBm PPrach:10dBm DL:637333 UL:637333 3560000kHz 3560000kHz 11dB -90dBm -9.0dB
31-10-2021 06:29 PM
Hi I'm actually out at the moment I'll have a look at the info a bit later when I get back
