on 25-03-2021 10:13 AM
My 'moto g8 Plus' is suddenly having difficulty recognising my finger print, it's a bit hit and miss, mostly miss. I do not think my fingerprint is the problem, as other devices do recognise the fingerprint on the same finger. Suggestions please, thank you.
on 25-03-2021 10:19 AM
Hi @Hannes
Have you changed the screen protector? I've had issues with thicker screen protectors.
If not, give the screen a clean and reboot. I've even experienced this as i've been washing my hands more often.
One more tip is to delete your finger print, then scan it again. You can also scan the same finger twice to improve recognition.
Thanks,
Martyn
on 25-03-2021 10:27 AM
Thank you for your very prompt response.
I have made no changes, but I will certainly try your other very good suggestions.
Thank you.
on 25-03-2021 11:04 AM
