11-05-2021 11:05 PM
On a regular basis, my fibre broadband speed drops to less than 1Mb at various times of the day, or overnight. If I reboot the router it comes back up to around 27Mbps and is OK until the next time it happens.
This has only started happening recently - up until then I was getting up to 60Mbps and no drop-outs. Can anyone advise me on what to do, please? Many thanks in advance.
12-05-2021 12:40 AM
12-05-2021 08:30 AM
Thanks for the assistance.
Log:
12-05-2021 08:33 AM
| 80 | 79 | 20 | 19 | 74 | Available | Available | -- |
| 80 | 78.8 | 20 | 19 | 74 | Available | Available | -- |
| 330 | 30 | -- | Available | -- |
| Up to 15.5 | -- | 14 to 17.5 | Available | Available | -- |
| Up to 15.5 | Up to 1.5 | 14 to 17.5 | Available | Available | -- |
| Up to 8 | -- | 7 to 8 | Available | Available | -- |
| 2 | -- | -- | Available | Available | -- |
| 2 | -- | -- | Available | -- | -- |
| 80 |
| 20 |
| 2021-03-19 |
| Available |
| Available |
| N |
| N |
| N |
| 26-04-2021 |
| N |
| N |
| Y |
The premise/line is associated with exchange which is NOT part of current fibre priority programme.
The premise/line is associated with exchange where WLR is not withdrawn.
The premise/line is associated with exchange where SOADSL service is restricted.
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 31 Oct 2013. The Formal Retirement date for IPstream is from 30 Jun 2014.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Thank you for your interest
By submitting a query into this checker you accept Terms of Use for this checker.
12-05-2021 08:34 AM
Unable to do a wired speedtest at present but will try later. Many thanks.
12-05-2021 08:40 AM
You are actually getting the top speeds for your Fibre Plus product, 80/20 Meg.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
12-05-2021 08:58 AM
I don't have a split faceplate and I couldn't bend down to unscrew it anyway, apologies.
There is one extension socket which is in use, none unused. It's not so much the speeds that concern me as they dropping down to nothing every day which is fixed by a reboot. Could the router itself be at fault? Many thanks again for your help.
12-05-2021 09:06 AM
Do the QLT from the front master socket anyway.
12-05-2021 09:13 AM
Done - no noise.
12-05-2021 11:52 AM
Hi @ianfreeman
If you give our Broadband Tech team a call on 0800 079 8586 they will get this looked into for you.
Thanks 🙂
