| For up-to-date information and comments, search the EE Community or start a new topic. |
30-08-2021 11:17 PM - edited 30-08-2021 11:22 PM
HEEEE-E-E-E-ELP!
My black and yellow, 4g wifi device is misbehaving.  My connection was dropped, so I tried to do the 10 seconds hold of the on/off button...that didn't do anything, because absolutely no lights were on, at all, before/during/after trying that.
Then, it changed to how it is, now...EVERY LIGHT IS CONTINUALLY ON!  Five green LEDs, 3 blue LEDs and all 4 segments on the button...all of them, constantly on.
That's been the way it has been for over an hour, now, and it is really depressing me.  I want my service...the Net is really important to me.  Why is EVERY light on?  How do I fix this?  I've done the whole take out the card thing, and the use the reset function a good few times, and they've not helped, at all.  I think my device might have died.  If it has, can I get another sent out to me?
What am I missing?  My Net is really important, guys...desperately in need of rescue, here, folks!  ☹️
Ian.
31-08-2021 08:39 AM
Hi and welcome to the community, @TheGodSplinter
Are there any maintenance works in your area? You can check by putting your postcode into our coverage checker and hitting 'check status'.
31-08-2021 08:39 AM
31-08-2021 09:16 PM
Hi.
Thank you for getting back to me.  Yes, there are some works ongoing, at this time, and that could well be the reason.
I disconnected the device from everything, including its own lead, and waited until all those lights went out because the battery was dead.  After doing a mains-plug re-charge, the problem vanished and everything is back to normal, again.
Thanks for the reply, and thanks for being there.
Ian.
01-09-2021 07:49 AM
