30-11-2021 10:49 PM
This is doing my head in.
I've got a 4Gee Home Router on the unlimited plan thats often only getting 5-9mb on a speed test (with device directly plugged in via ethernet) and over 150mb+ from my iPhone 12 on EE 4G sitting right next to it. Both with the same service bars, both with the same 4G only setting configured.
Is there a profile, an APN or something that could be setup different in the devices? I cant understand the significant different, especially when both have full bars.
Has anyone noticed significant performance difference between their 4Gee router and their mobile LTE?
I use the 4Gee for my home internet and often end up tethering my mobile, which is costly and inefficient.
Thanks for any help.
30-11-2021 11:38 PM
Out of interest have you swopped the Sims over between each device and do you get the same results.
06-12-2021 02:47 PM
Hi There... Yes - Swapped Sims over and getting the same result. So doesn't seem to be the Sim cards - looks like its the 4Gee device.
06-12-2021 03:11 PM - edited 06-12-2021 03:11 PM
Hi @nickcondon
If you give us a call our Tech Gurus will get this looked into for you.
Thanks 🙂
