EE broadband issues
Kath48
O used to have no issues with my broadband till they decided to upgrade things a few months ago now for the past week I'm struggling to connect to my now TV as my broadband keeps dropping off comeon EE sort it out please
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
