close
EE accidently blacklisted my iPhone 12 pro
rafiqul3
I called EE today to find out when I can unlock my phone
They took IMEI to check
But while checking they accidently clicked on add to blacklist!!
Such a stupid thing to do...what a **bleep**!!
Now I can't use my phone to make calls
Profile closed
Not applicable
Hi @rafiqul3
Welcome to the EE Community,
you will need to contact EE customer services to get the blacklist removed if you call freephone 0800 317 720 a customer service advisor will be happy to assist you.
Thanks,
David.
9 REPLIES 9
Profile closed
Not applicable
Hi @rafiqul3
Thanks,
David.
Thank you
But I spoke to EE already on 150 number
They refused to help
Get Outlook for iOS
They made a mistake, eh? Why couldn't they just uncheck it & reverse it? That's what peeps do when they make a mistake - correct it!
Katie_J
Hello @rafiqul3
Since your last post have you been able to get your phone removed from the blacklist?
Katie 🙂
@rafiqul3   Did you get the device yourself from EE ?
hi there
no luck, sorry!
Dont knw what to do
I have asked EE to remove unblock, but they cannot do it as i bought the phone from ebay seller
Ebay seller is not responding
No, from ebay seller
ebay seller got from ee upgrade
@rafiqul3 , is it possible that the eBay seller, after selling it to you, then reported it as lost or stolen and when EE had a look, discovered this and blacklisted it and this is why the eBay seller is not responding?
The eBay seller wrote, he got it from EE upgrade, the phone cannot be sold for the first six months, and so that is probably why it has been blacklisted, as EE will not unlock the phone until the six months are up. Sorry, but I would suggest contacting EBay and the seller, who had no right to sell the phone in the first place, as it is less than six months old and still belongs to EE. I believe there are other routes you can take to get your money back, but not sure and hopefully someone else will come up with some ideas. Always be careful where and who you buy from, when an item is so expensive.
