close
EE Hub resetting multiple times a day
IANNEADE
This happens to my HUB most nights at 9pm and also sometimes at 10pm, I have phoned tech support quite a few times with three visits from Openreach Engineers and one cube technician who couldn`t tell me why. Why is this happening EE and not to just myself. Don`t tell me its noise on the line because the two BT engineers found none
13 REPLIES 13
That SH is also giving you the top speed, 40 Meg, for your BB product as the 1st 1 you posted. You should be seeing no diff in speed.
That is hub 3 and its reset once since iv`e set it up, and its an experiment by myself to use my phone as a hotspot from that router which gives me extra speed, the thing is me and my wife has the same laptop with same specs her gets the full speed with all routers my laptop only gets the speed from hub 1. Hub 2 and 3 I get 7mb download
Then the issue is with your WiFi connection.
Try a speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph. Do this with routers 1 & 3.
1st link is hub 3 using my phone as a hotspot and laptop connected to it
https://gyazo.com/27c544a420efccda366c0ebf69c57453
2nd link my laptop is connected to hub 3 directly
https://gyazo.com/31d64c8b89550073f15c5e7a3ae7b458
Hub 1 gives me constant 36gb download as it does with my wife`s  hers will also get 36gb when connected to hub 3
