close
EE 4GEE Wifi Mini
Mhanson295
Ive recently bought the Wifi mini and it has been working till this morning. Currently it only shows 4 blue lights and doesnt change if I reboot it either by the power button or the reset inside.
Any help will be appreciated.
7 REPLIES 7
Leanne_T
Hi @Mhanson295
When you pressed the reset button, did you use a pin? also, did you press and hold it for around 15 seconds?
This would reset the device.
Thanks 🙂
@Leanne_T : Do you mean a PIN (Personal ID Number) or a pin 😉?
@Leanne_T
Yes, I have held it down for around 15 seconds, is there anyway to tell if it has reset?
Does it still transmit WiFi and if so does it let you logon to the WiFi if so, login into the Admin Page and see if there are any obvious errors showing.
Leanne_T
Hi @XRaySpeX
Thanks for keeping me right 🙂
@Mhanson295 are you able to follow the advice from @EssexBoyEE
Thanks 🙂
No, it wont transmit at all and it wont load on the admin page. Ive had to organise getting it swapped. Thanks
@Leanne_T @EssexBoyEE
Jon_K
Former EE Employee
Thanks for letting us know you're getting it replaced, @Mhanson295.
Let us know how you get on when the new one arrives.
Jon
