close
Data usage
susanne2
I've had a data usage notification to say I've used 101.12 GB out 103. I don't understand why when I only ever use maximum 7GB a month.
It doesn't renew until 2nd January 2022. How can this be?
Many thanks.
What's the actual wording of this msg?
mikeliuk
Hi @susanne2 ,
The below reference should help you track down the app or apps responsible for this, whether iPhone or Android.
https://lifehacker.com/how-to-see-which-apps-are-using-all-your-data-1836366047/amp
If you never intend to use more than 7 GB in a month, you can set a limit with appropriate refresh date to better keep on top of your usage.
