close
Daily drop in connection
lez632
I have monitored my internet for the past month & it has gone down 17 times to what i no too.
It's VERY annoying when you are in the middle of doing something.
I have had problems ever since i got fibre broadband,
Been in touch with EE on loads occasions regarding this, they seam to sort it out then it goes back to the way it was, I never had problems with my old broadband.
It's like there is someone on the other end cutting the sauce of power.
You pay a lot of money each month for broadband, you expect it to be 100%. Yes sometimes there may be a time when it does go down but NOT every day.
Dose anyone else's fibre broadband go down almost every day?
If this continues to happen i think a change is in order.
Leanne_T
Hi there @lez632
Is this is happening daily, I would suggest getting back in touch with our Broadband Tech team on 0800 079 8586 and the team will get this looked into further for you.
Thanks.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
