close
Can't use data on iPhone 12
wezmeister17
I bought my daughter an unlocked iPhone 12 from Amazon. She is unable to access her data. All locks are off. She can make and receive calls. When I put my ee sim in data works fine. Her ee sim is part of my plan so is there a reason why her data isn't working?
11 REPLIES 11
Northerner
Hi @wezmeister17
Try resetting her network settings.
Already tried that no luck
Does her SIM work in another phone?
Does it get a 4G signal?
What happens when your daughter tries to use mobile data?
Okay so after trying her SIM in my phone (galaxy S20+) data doesnt work so I can only assume it's a sim card issue
Appears like it - see if you can get a SIM replacement
James_B
EE Community Manager
Hi @wezmeister17,
Is it using a pay as you go or pay monthly plan?
Can it make calls and send texts successfully?
Yeah it can make and receive calls data is the only issue
It's a pay monthly, it's a second number on my account and mine works fine
