Can't connect to London underground wifi
EELondonUser
Hello,
I bought a 15 pound pay as you go sim a couple of months ago. I have topped up a couple of times during that time with 15 pounds each month. Unfortunately, I still can't connect to the London Underground wifi. I'm on android and I keep getting authentication error even tho I set authentication to eap sim
Is there anything else that I have to do?
Cheers
6 REPLIES 6
James_B
EE Community Manager
Hi @EELondonUser,
When was the last time you topped up?
You need to have topped-up in the last 30 days to be able to use WiFi on the London Underground.
Hello, I last topped up 15 pounds on the 5th or 6th of October. I tried it at multiple occasions after the top up, e.g. ylthe next day, a week later etc.
Cheers
Katie_B
Hello @EELondonUser
Thanks for confirming.
I would recommend reporting this to our technical care team who can look into this further for you.
Katie 🙂
Thank you for the responses. How can I get in contact with the technical care team?
Cheers
See "Contact EE" above R.
