close
Can't answer calls
talipsychocat
Please help me, over the last 2 weeks I have been unable to answer calls on my s20. It rings but then I just get a blank screen, no contact info or options to answer. Also when I make a call I get a blank screen and cannot pull up the keypad to select any options, I then get a message saying the app has crashed. Any advice??
9 REPLIES 9
Leanne_T
Hi @talipsychocat
Are you using a downloaded app to make calls or the standard phone app on the Samsung?
When this happens are you connected to WiFi?
Thanks 🙂
It is the standard phone app. It happens when I am on WiFi, 4g or no Internet connection.
Leanne_T
Thanks @talipsychocat
Could you try the steps in the Samsung support page, and let me know if this fixes the phone app crashing?
Speak soon 🙂
I have tried all those things prior to posting I'm afraid. I have drawn the line at the factory reset as I don't want to lose all my stuff 😵
Leanne_T
Thanks for trying this @talipsychocat
The factory reset would be the next step to try, you can back up all your data before you do this.
You can find information in the Samsung - Back up and restore data.
If you can try this and let me know how you get on?
Thanks for your help. Manages to avoid a reset as my partner pointed out I downloaded a galaxy theme at the time things started to go wrong. Deleted the theme and it seems to be fixed now.
Maybe that needs looking at though 🤔😁
Leanne_T
Thanks for letting me know @talipsychocat
Was the theme downloaded from the 'Themes' section on your Samsung phone?
Thanks 🙂
Yes it was...... an alice in wonderland neon animated theme.
Leanne_T
You can report this to Samsung and let them know this has happened 🙂
