close
Brodband disconected
Peter179
Hi, for the last 3 days my broadband connection is disconnecting the internet, interestingly it may disconnect several times during these hours only from 8:30 am to 2:30 pm to 3:00 pm after that time it works normally
36 REPLIES 36
Peter179
hello it's again me with the same problem as described above my home brodband after some time start to disconnect the connection, if it continues then i will end the contract with EE
Please provide again the info I requested in my original reply to your OP as it is now.
Peter179
https://www.thinkbroadband.com/speedtest/1608651387897066255
Cabinet 6
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low      VDSL Range A (Clean)
VDSL Range B (Impacted)
67.351.5201546.5AvailableAvailable
6647.52012.940AvailableAvailable
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability DateWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 12--7 to 17Available
Up to 12Up to 17 to 17Available
Up to 6.5--5.5 to 8Available
2----Available
2----Available
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
Peter179
You are still or again on a banded profile at the top of the up to 40 Meg band of these VDSL Banded Profiles. Has it been much faster between last time & now?
How's the BT QLT this time?
Peter179
Hello,
The quality line is the same as before without any noise. When will everything go back to normal? Is there anything you can do or do we still have to wait?
Wait! You haven't said how the line was in between & what happened last time..
Peter179
Last time I had the same problems like last time. The internet kept going off and I checked the line quality by home phone. It is said in the messages above.
But how was it fixed & what was it like afterwards? You haven't told us.
Peter179
i don't know how it was fixed, it just started working and it was fine about a month and now the problem is back again
