Brodband disconected
Peter179
Hi, for the last 3 days my broadband connection is disconnecting the internet, interestingly it may disconnect several times during these hours only from 8:30 am to 2:30 pm to 3:00 pm after that time it works normally
The DLM system has put you on a banded profile in response to past errors on your line, at the top of the up to 40 Meg band of these VDSL Banded Profiles. You need to give the DLM time to relent & remove any banding. If your sync speed at the test socket remains stuck at the same speed for 10 days you should ask EE to investigate the underlying fault. If a fault is found and fixed then the OR engineer may request a DLM reset. However should significant errors persist the DLM will reapply banding.
36 REPLIES 36
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
3. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Peter179
https://www.thinkbroadband.com/speedtest/1605370622275677755
UPRN 100030727820 on Exchange BOSTON is served by Cabinet 6
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low      VDSL Range A (Clean)
VDSL Range B (Impacted)
67.351.5201546.5AvailableAvailable
6647.52012.940AvailableAvailable
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability DateWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 13--7.5 to 17.5Available
Up to 13Up to 17.5 to 17.5Available
Up to 6.5--5.5 to 8Available
2----Available
2----Available
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
The premise/line is associated with exchange
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
Peter179
Product name:Smart Hub
Serial number:+EEH001+1850015118
Firmware version:v0.05.02.04290-EE
Firmware Updated:Thu Jun 11 01:57:39 2020
Board version:01
DSL uptime:0 Days, 0 Hours, 5 Mins, 13 Secs
Data rate:12.00 Mbps / 39.99 Mbps
Maximum Data rate:16.43 Mbps / 65.59 Mbps
Noise margin (up/down):6.5 / 7.7
Line attenuation (up/down):21.1 / 17.6
Signal attenuation (up/down):21.0 / 17.7
Data sent / received:2.9 MB / 66.7 MB
Broadband username:
2.4 GHz wireless network name:EE-Hub-6k2F
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:EE-Hub-6k2F
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:44:FE:3B:E0:6E:4B
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017).                                         BT quiet line test done for me the signal was clear
Peter179
ok thank you for your help and i'm waiting 10 days i hope everything will be ok
@Peter179 : How did you get hold of your UPRN?
Thanks.
