| For up-to-date information and comments, search the EE Community or start a new topic. |
21-06-2021 04:16 PM
Hello,
I have recently returned from an extended trip to India. Whilst in India I used a local SIM.
I have a minutes and mobile data pack. The calls and texts are working fine but the internet is not working. Has anyone any suggestions?
Thanks in advance.
22-06-2021 09:56 AM - edited 22-06-2021 09:57 AM
Thanks @Stuckinindia
Can you check the APN settings are correct using the EE APN Settings: Where to find them, post for guidance.
Let me know how you get on 🙂
21-06-2021 04:43 PM
When did you last use the EE SIM you are now using?
What does texting AL to 150 from it fully report verbatim (it is free)?
22-06-2021 08:20 AM
Good morning,
thanks for the reply. I last used the SIM in India to receive texts last week. Last used in UK 2019.
The message from AL is;
Your current balance as of today 08:12 is £0.50. You have 520 minutes, unlimited texts and 5.5GB remaining until 20/07/2021 for your £10 Talk Pack. Your remaining data includes of rolled over data. Your last top up was £5.00 on 14/12/2020 at 06:19. For more info on your packs, add-ons or free boosts, go to MyEE. ee.co.uk/myee
For info on our other Text Services, reply HELP or go to ee.co.uk/textservices
22-06-2021 08:40 AM
What happens when you try and use any apps or the internet?
Thanks 🙂
22-06-2021 09:43 AM
with the WiFi off and the mobile data on it says no internet connection please connect to network or WiFi.
22-06-2021 09:47 AM
Would the configuration settings of the Indian sim have altered anything?
22-06-2021 09:48 AM
Just to check, can you make calls and send texts?
What phone are you using?
Thanks 🙂
22-06-2021 09:53 AM
Hello,
it's a Samsung core prime and yep, the texts and calls are working fine.
22-06-2021 10:13 AM
Hi Leanne,
thanks for taking the time to help. I'm currently quarantining next to Heathrow and my son wants a live aeroplane show when I go for my daily prison exercise in the car park next to the run way but the WiFi doesn't reach that far.
I now have mobile internet thank you for solving the problem. I shall now go show my son aeroplanes.
