22-09-2021 11:19 PM
Hi
I've had EE broadband since July 2020 but in June 2021 my broadband has started to drop offline then come back online 1-2 mins later.
I noted down the dates/times it was happening and this happens at roughly the same time every day (5:30pm-6:00pm). It's been doing this for 3 months now and has happened every single day.
Let me know what information I can provide to help diagnose the issue.
23-09-2021 01:58 AM
Is there some electrical plant in your vicinity starting up/shutting down about that time?
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
23-09-2021 02:36 AM
There's no nearby electrical plant as far as I'm aware. The router itself isn't restarting or switching off, just the broadband connection.
All devices connected both wirelessly and through internet will lose their connection to the internet. The light will flash yellow then go solid yellow until the internet starts working and then the light goes blank (I have the light turned off in the settings).
Screenshot of router stats:
Broadband availability checker:
Hope this helps.
23-09-2021 04:28 AM
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. Do this both at the bad time & outside it. Is there any difference? If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
23-09-2021 01:51 PM
Unfortunately I don't own a landline telephone, is there any other things I can try?
23-09-2021 02:34 PM
The QLT is the most important test to help diagnose faults such as yours. Noise on the line is the most common cause of BB failing or going slow.
A corded phone handset is the best diagnostic tool you can have for BB. I strongly recommend getting a cheap corded handset to help diagnose BB issues like yours as well as keeping the line "wet" to help avoiding BB issues & paying out for an engineer to fix faults in your own wiring.
