close
Broadband bar lift
Lucycusack87
How can I lift the bar on my broadband?
@Lucycusack87   What bar there isn’t any bar on BB.
   Unless you live not paid your bill,  if that’s the case you’ll need to pay it.
@Lucycusack87 : Welcome to EE's Home Broadband Forum.
What bar? Are you thinking your BB speed is being limited?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
