Broad band drop outs
Skmaee
Added a mesh WiFi system to improve coverage. Ran okay for a few days so switched off the EE smart hub WiFi as I did not need it. Then started to have issues with regular drops in internet service. So did a reset which turned the EE smart hub WiFi back on. This solved the problem! Why would turning the WiFi off cause problems?
pip11
Scholarly Contributor
Why would you need to turn it off if doing so caused problems? If it works don't try to fix it.
pip11
Just try to reduce number of WiFi signals and why have it running if I do not use it.
