‎21-03-2021 01:39 PM - edited ‎21-03-2021 01:50 PM
Looks like the bright box 2 router time sync is not working again.
Should be syncing to ntp.madesimpletechnology.com but the date shows as 01 Jan
None of the Time settings are configurable on the router so I'm reliant on either EE using reliable time servers or ntp.madesimpletechnology.com actually working consistently.
This messes the access time schedules that I have set on the router don't work correctly.
Anyone else seeing this issue?
Dave
‎17-09-2021 05:02 PM
BTW (and I noticed this even before the fix), my system log shows A LOT of "Possible DoS attack detected from xx.xx.xx.xxx" type messages...is that normal???
‎17-09-2021 05:23 PM
Oh right:
So...normal enough, then..?
‎17-09-2021 05:33 PM
@MBEE : Funny you should say that. I've had lots of DoS attacks detected just since yesterday. The router is doing its job!
‎27-09-2021 01:09 PM
So this might be worth noting / help somebody else, forward to earlier posts...
My broadband died earlier but I had all 4 lights green on the front of the BrightBox 2; whilst my devices were connecting to it OK, they all said 'connected, no internet'.
Land line was functioning properly.
After rebooting, checking master socket, external cable and whether any engineers were working on the local cabinet across the road from my house (they weren't), I rang 150.
After about a half hour of (successful) line tests, router factory resets and config restores, the rep asked for the router serial number, at which point she realised my broadband account still listed my original Bright Box 1 details and serial number. She refreshed these details and hey presto, broadband instantly back up and running.
Seems my Bright Box 2 was still listed against the original owner's account; all I can think is maybe EE systems automatically check the details on your account from time to time against those being reported by your hardware (presume they would need to do this for firmware updates, etc.) and may deny your service if there's a mismatch?
tl;dr, moral of the story: if you're going to use a 2nd hand EE router, might be worth giving EE tech support a call on 150 and giving them the router model and serial number to list against your account.
‎01-10-2021 11:54 AM
I'm in the same situation. I use a second hand BB2 because I had problems with the SmartHub continually dropping connection. ( 7 or 8 times a day)
The BB2 has a far more stable connection but it stills drops out occasionally, usually evenings or overnight but only 3 or 4 times a month.
The time server on the BB2 has never worked, it is set to NTP.READYTOCONNECT.CO.UK
It's not a major issue, but every time it drops out the system log goes back to 1st Jan
‎02-10-2021 02:33 PM
I've sent you a private message for some details.
‎08-10-2021 10:21 AM
‎08-10-2021 10:32 AM
