Brightbox 2 Time Sync Not Working Again
Hutch641
Looks like the bright box 2 router time sync is not working again.
Should be syncing to ntp.madesimpletechnology.com but the date shows as 01 Jan
None of the Time settings are configurable on the router so I'm reliant on either EE using reliable time servers or ntp.madesimpletechnology.com actually working consistently.
This messes the access time schedules that I have set on the router don't work correctly.
Anyone else seeing this issue?
Dave
27 REPLIES 27
Yes, since after 02:24:59, 17 Mar. All you can do is call CS & report it.
Thanks for the confirmation.
I've had this before and someone from CS contacted me via a private message and somehow fixed it. If I remember correctly they just wanted the serial number of the router.
Unfortunately I have had to setup a new user ID in this community as I couldn't find/remember my previous one, so can't see any history of my previous posts
Dave
Can't see why they need your router's SN. It's a server down situation that affects all Brightboxes.
What was your previous ID?
This was the original post https://community.ee.co.uk/t5/Broadband-home-phone/The-madesimple-ntp-server-again/td-p/868603
Original ID was Hutch64 and a Christopher_G private messaged me
If you either:
  1. Click on the "Hutch64" in that thread, or
  2. Search in the search bar above for "Hutch64" in Members,
you will find all (2) of your previous posts.
What's stopping you continuing tp use @Hutch64 ? It still exists. Have you forgotten its pwd? You can change that.
Christopher_G
Hi again @Hutch641
I've reported this to my colleague who I spoke to the last time you raised this to us.
Hopefully it'll be back to normal soon for you.
Thanks 🙂
Thanks @Christopher_G
I'll keep an eye on it
Christopher_G
Hi @Hutch641
Should be working OK now, could you give it a check for me please?
Yes, it's working for me now & has even, surprisingly, corrected all the Jan. dates in the log. Thanks.
