‎21-03-2021 01:39 PM - edited ‎21-03-2021 01:50 PM
Looks like the bright box 2 router time sync is not working again.
Should be syncing to ntp.madesimpletechnology.com but the date shows as 01 Jan
None of the Time settings are configurable on the router so I'm reliant on either EE using reliable time servers or ntp.madesimpletechnology.com actually working consistently.
This messes the access time schedules that I have set on the router don't work correctly.
Anyone else seeing this issue?
Dave
‎22-03-2021 12:36 PM
‎22-03-2021 12:58 PM
‎15-09-2021 02:07 PM
Hi there, wondering if you could look at the same issue for me?
I just recently plugged in and set up a Bright Box 2 (I know, pretty old hardware still but an upgrade from the old, 'square version' Bright Box 1 I was STILL running, all the same!) and it has upgraded automatically overnight to the following, which I think is still current:
Runtime Code Version
v0.06.00.0001-OT (Tue May 19 15:34:07 2020)
Boot Code Version
0.0.9-OT (Thu Aug 8 18:14:37 2013)
However:
Time settings are still showing the older 'NTP.READYTOCONNECT.CO.UK' server, so my time and system logs remain incorrect; not sure if this might update automatically in due course? So far, I've tried:
- Disabling Automatic Time Server Maintenance, saving, then reenabling it, saving and rebooting.
- Backing up router config > factory reset (after which no change, I checked...) > restoring config.
Any advice?
‎15-09-2021 02:38 PM - edited ‎15-09-2021 02:38 PM
@MBEE : I also have:
| Runtime Code Version | v0.06.00.0001-OT (Tue May 19 15:34:07 2020) |
| Boot Code Version | 0.0.9-OT (Thu Aug 8 18:14:37 2013) |
but NTP Server = ntp.madesimpletechnology.com
‎15-09-2021 02:57 PM
Yeah, me neither; thanks for chiming in with your spec all the same, good to know the firmware seems all up to date at least.
Am hoping @Christopher_G might be able to advise further, as seems from the above as if he managed to pull some strings in the background with the relevant EE team?
‎17-09-2021 10:18 AM
‎17-09-2021 02:31 PM
@Christopher_G , many thanks, as per your PM, I can confirm this now seems fixed.
Time Settings now show server as NTP.MADESIMPLETECHNOLOGY.COM , I have a couple of recent system log entries stating "Time is synced to NTP server", current time and date is correct and as others reported, recent previous log entries have also been updated with the correct time.
Thanks again!
‎17-09-2021 02:33 PM
‎17-09-2021 02:35 PM
@MBEE : How was it fixed?
‎17-09-2021 04:54 PM
I provided my router serial number (via PM, of course) and seems this allowed a MAGIC FIX to be pushed to it by EE !
