Better offer than 60GB mobile data
Banjanja
I can’t find a better offer on EE than the 30 pound for 60GB of mobile data. I need more data, I use more than this in a month and would like to increase it, how? Advice?
I can’t find a way to reach out to ee directly and ask them this
EssexBoyEE
How long have you had your current Plan, Sim Only?
Log into your Account or App, Vew Plan / see Upgrades / See All Phones / Select SIM Only Option / then have a butchers at the new 5G SIM Only Plans that are on Offer to you, you should see 160gb, 200gb and Unlimited Data plans, all hopefully with some Discount already applied  for being an Existing EE Customer.
